Won't start
Haigh88
Won't start
Postby Haigh88 » Sun May 15, 2022 4:11 pm
Had problems with air getting in the fuel system before, and I usually just bleed the three screws.
This day I was working with the tractor, on and off during the day. The last time I got it running Cranked the starter and didn't start. Cranked the starter and the flywheel must of been still spinning. Gave the tractor a rest for 30 seconds.
Bleed the 3 screws and started the tractor. Heard a whining/light whistle of air sound and it went away by the right side. Tractor turned off.
Bleed lines again, started Tractor heard whining/whistle on right side. It went away after Tractor work for 10 minutes and then I turned the tractor off. Waited a half an hour and went to start and she wouldn't start. The tractor cranks but won't start.
Before the tractor died. The tank had been running off of fuel that It had while purchased. It still had 20% old diesel fuel that it has been running on when I put 5.16 gallons of fresh fuel with sea foam additive and stabil diesel all season and a new fuel filter.
Any help would be much appreciated. Thanks
Re: Won't start
Postby winston » Tue May 17, 2022 8:52 am
What model tractor? Does the fuel in the filter bowl look nice and clean? Are you getting a good flow of fuel when you bleed? Have you read this? https://www.hoyetractor.com/bleed.htm
https://www.youtube.com/watch?v=x7Gn_EsSd_k&t=33s
Haigh88
Re: Won't start
Postby Haigh88 » Wed May 18, 2022 8:33 am
The model of the tractor is 2210D, the tractor does bleed fuel on all three bleeder screws.
Re: Won't start
Postby winston » Wed May 18, 2022 1:48 pm
Probably haven't messed with them at all but if you possibly tried to loosen injector lines at pump you might have accidently loosened the delivery valve holders. That is #12-1 on this drawing. https://www.hoyetractor.com/CTGY/YM2000INJPUMP.htm
Telling you this because I just run into that on a 1720. They are to be torqued to 29 to 32.6 ft lbs or goodntight. Lines will suck air if not.
Users browsing this forum: No registered users and 16 guests
